1 - 16 of 16 Posts
As the title asks...<br><br>
Never seen it happen.
<div>Originally Posted by <strong>ThaWaxShop</strong></div>
<div style="font-style:italic;">it will either<br>
A) throttle<br>
B) shut itself off</div>
</td>
</tr></table></div>
Then how does a CPU "get fried"?
voltage ( or heat ) destroys the "gateways" inside the cpu core, thats what it means for when a cpu is fried.
<div style="font-style:italic;">it can still damage the chip. But mostly from too much voltage.</div>
</td>
</tr></table></div>
Exactly. Too much heat can damage a chip, but modern CPUs have good enough saftey measuers to keep that from happening. The easiest way to "fry" a chip is by feeding it too much voltage, which you often won't notice doing damage until it's too late. The is generaly a max "safe" voltage range for CPUs, I'm not too familiar with C2D's, but Wax can probably tell you.
Discussion Starter #7
<div>Originally Posted by <strong>Chipp</strong></div>
<div style="font-style:italic;">Exactly. Too much heat can damage a chip, but modern CPUs have good enough saftey measuers to keep that from happening. The easiest way to "fry" a chip is by feeding it too much voltage, which you often won't notice doing damage until it's too late. The is generaly a max "safe" voltage range for CPUs, I'm not too familiar with C2D's, but Wax can probably tell you.</div>
</td>
</tr></table></div>
Wax, whatdya say to 1.41 on the core?<br><br>
Thank you.<br><br>
P.S. I know that the answer(s) to this question is almost everywhere.. just wanna hear it from one of you guys. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
From what I've seen/heard, the max you should run 24/7 is about 1.75 vCore, no matter what the temps, but people will run more for suicide runs and such.
Reactions: Syrillian
Discussion Starter #10
Right on! Thanks a lot guys. Your assistance and answers are always appreciated.<br><br>
I've been hanging around for about 2 months, and lurking for 4. I have always been impressed by the turnaround time for posts.
Thats what we are here for <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Administrator
Technical information regarding the ability of the chip to prevent damage to internal components and circuitry.<br><br>
Note: Most of these safety features will be active after approximately 100C for certain to prevent damage to the internal components of the Core 2 Duo processing modules.<br><br>
1. Internal bus system goes offline (certain revisions). Data can still be transferred between internal components using outer bus array.<br><br>
2. Auxiliary components (including secondary FPU cores) will be taken offline, as in lower power mode. This prevents damage to these components.<br><br>
3. Thermal Control 1 will be active. This will prevent full 100% load from occurring by inserting idle cycles into the processor work queue. This will impair performance and will also reduce the thermal conditions inside the processor.<br><br>
4. Thermal Control 2 will be in forced modular mode (certain revisions). This will force a lower multiplier to be used and therefore the voltage requirement will be reduced.
<div>Originally Posted by <strong>Syrillian</strong></div>
<div style="font-style:italic;">As the title asks...<br><br>
Never seen it happen.</div>
</td>
</tr></table></div>
It will explode, turn into a fireball and kill you...<br><br>
Nah that won't happen ofcourse.. The highest safe temps are 60,1C, but it will not throttle untill 85C, so your cpu could get damaged..
I really like the safety features they have on the PCs these days. One day when I was working on my mobo, I accidentally dislodged my heatsink from the CPU (1 of the clip came loose). Fortunately, the PC immediately shutoff after I powered it up. I had set my mobo to shutoff if cpu temp goes past 75 degrees. In the end, my CPU is still working and running strong.<br><br>
Edit: Moral of this story, turn on safety check features on mobo if available.
I remember when......
<div>Originally Posted by <strong>Namrac</strong></div>
<div style="font-style:italic;">From what I've seen/heard, the max you should run 24/7 is about 1.75 vCore, no matter what the temps, but people will run more for suicide runs and such.</div>
</td>
</tr></table></div>
<br>
Just so it's on the record......I would never recomend you run 1.75 unless you have liquid nitrogen.......I would seriously question anyone advising this as a "safe" 24/7 voltage as to how much money they have, because they must like buying CPUs, and doing so often.<br><br>
We'll see how many of these CPUs are still functioning in a year......
Discussion Starter #16
There is no concievable scenario that would lead me to 1.75 (that I can think of <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"> )<br><br>
I am at 1.41V / 43C-54C @ 25C ambient (+ 9C {+/-} above stock clock). I think that is far as I will take it until I switch to H2O next summer. I certainly wouldn't run it like this during the summer here in California (with no A/C).<br><br>
So far, so good, it's stable....<br><br>
It's all over the place - in the am with an ambient of 22C it's 34C on the core <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> . In the pm with an ambient of 25-28C it's what is listed above.<br><br><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"> Oh well, it seems okay
1 - 16 of 16 Posts
