What does ram voltage mean?
2203 Views 9 Replies 6 Participants Last post by  pLuhhmm
Im looking at some ram and one has 2.1 and the other has 2.2, the 2.1 costs $5 more so what does ram voltage mean and do?
1 - 10 of 10 Posts
It shows how much volt it needs to operate. Like CPUs have vcore.
the lower the voltage having lower timings gives more room for OC
are there any advantages or disadvantages for 2.2 or 2.1?
Im looking @
http://www.newegg.com/Product/Produc...82E16820227298
and
http://www.newegg.com/Product/Produc...82E16820227289
Yeah it's simply the voltage they operate at. If they run below it, your system might not be stable. Too far over the recommended voltage and you might fry them.
Edit:
This set is a better deal:
http://www.newegg.com/Product/Produc...82E16820227406
i have the ocz plat and they are not that good, go for the reapers.
Im looking @ these parts for this build.
http://www.overclock.net/intel-gener...ld-review.html
dude, if you don't have money for a decent c2d processor it doesnt mean that you have to go with pentium E5200....
search our forums for private sales and get something like e6600 at least
Not necessarily. Some ICs don't scale with voltage very well. Most of the 2x2GB kits don't.
The e5200 is a dual core and i can just OC to 4ghz.
1 - 10 of 10 Posts
