What does this error mean?
11765 Views 7 Replies 7 Participants Last post by  bluemagicuk
I have an Asus A8N-SLI Premium, I have tried 2 different versions of PC Probe 2 and still get the same error. If I enable the PC Probe to run during boot up I get the error "Enumerate Device Win32_Bios Fail !!" This is frustrating. If I use OCCT and select Pc Probe for it to use, it just hangs. OCCT will work only if I don't use a temp program with it.
Please help
1 - 8 of 8 Posts
Please help
Dont the Motherboard you have provide you with software to monitor your temps voltages and so forth?
Yes and I am using that software
It is from Asus, it came with it and I downloaded a newer version from Asus and it still does the same thing. Win32 I thought was used in Windows 2000 and when I do a search for that error, all related finds are concerning windows 2000. I have no idea what to think.
hey all i get the same message at start up but now it has turned into more messages here they are it is asus probe i think ! it is weird tho because computer still runs fine ?
or tho the motherbord tends to overheat a bit
- Enumerate Device Win32_Bios Fail!!
- Enumerate Device Win32_Processeur Fail!!
- Enumerate Device Win32_BaseBoard Fail!!
- Enumerate Device Win32_DiskDrive Fail!!
- Enumerate Device Win32_CDROMDrive Fail!!
- Enumerate Device Win32_PhysicalMemory Fail!!
- Enumerate Device Win32_NetworkAdaptater Fail!!
- Enumerate Device Win32_VideoController Fail!!
- Enumerate Device Win32_DisplayConfiguration!!
- Enumerate Device Win32_SoudDevice Fail!!
- Enumerate Device Win32_OperatingSystem Fail!!
- Enumerate Device Win32_ComputerSystem Fail!!
system specs
am2 6000+ cpu
asus m2n-mx
7800gtx leadteck
4x 512 ddr2 667 kingston ram
if anyone knows what exsacly is causeing it or how to fix it please tell us asap as it is driving me crazy
do you have the latest version of your bios and probe?
not to fimilar with the probe but if its just temps you want give core temp a try or speed fan
yes...PCprobe is extremely buggy...on my PC if you try to run it at the same time as like an internet window and AIM then it'll shut off the comp. Best stick with coretemp or speedfan...much more stable. (And more accurate as well)
you need to enable windows management instrumentation in msconfig to fix this error ... er for the record even if 6 months too late
1 - 8 of 8 Posts
