1 - 8 of 8 Posts
Well im working on getting a lower vcore out of my 920. It passes 50 runs of IBT @ 4.0 with 1.216 vcore and the next step down is 1.200. I tried 1.200 and found this BSOD when i returned.
Anybody know what this code means? Im guessing that i need more vcore?
Originally Posted by MR KROGOTH
Are Speedstep and CIE off?
I know forsure speedstep is off. I'm not forsure if CIE is though. Does that code not throw up anything about cpu voltage?
Vcore issue 4 sure as you`ve passed with previous Vcore..
Now up it even a couple notchhes higher than 1.216 for 24/7 if you want to be BSOD free (especially if you`re using LLC that raises Vcore under load)..
CHEERS..
Discussion Starter · #6 ·
It passes 50 runs at 1.216 easily. I'll run some prime95 quick and see what that brings up. I'd like to keep my vcore as low as possible
And stable too..
Also I would recommend you to run memtest Windows verson 4.0..
Run 8 instances with 600MB of RAM for each and test it untill it reaches at least 100% on every one..
Then Run P95 LARGE FFT for at least 6h (12h would be ideal)..
CHEERS..
Discussion Starter · #8 ·
Originally Posted by KingT
And stable too..
CHEERS..
How's this look?
1 - 8 of 8 Posts
