If it help's.. it's a mac with W7 on it
it's the 2010 model 13.3" macbook..
In my sig.... what games can it run and at what settings?
^This is pretty much as good as you need of a source. I don't know how it will act in windows but I suspect part of the "better" battery life that a mac gets is from very strict throttling settings on battery so it will definitely work best on AC. Then again I can't honestly think of doing more than an 1hour without AC.Originally Posted by Aeschylus;13017829
Judging from the statistics, it ought to run Crysis at medium settings with acceptable frame rates. I don't think Crysis uses more than 2 threads, so your C2D shouldn't bottleneck it.
Remember that CPU-throttling on laptops kicks in with a vengeance when they aren't plugged in to a power source. You'll get better performance when you're on AC.
My take on this is just an opinion though. I'd recommend getting a good wide variety of input from different sources to make sure. Happy gaming.![]()
Because of the throttling and the high Whr battery combined with lower power using parts.Originally Posted by Divine spectral;13018005
battery life is 7 hrs.
About half the battery life? You may or may not notice a difference in performance.Originally Posted by Divine spectral;13018714
Gaming on battery what life cn i expect?
