1 - 8 of 8 Posts
Go with the second one, the ECS, it has twice the frame buffer of the first and will be much more future proof, as well as allow for higher levels of anti-aliasing in current games.
Ohh, Tnx mate i would go with dat then
Do you not have any other options?
Are you replacing the 8800GTS in your signature with this card? you do realize that the card you are "upgrading" to is simply a rebranded/renamed version of your 8800GTS right?
Nop its 4 my Friend
Yeah i knw dat they both ar renamed versionz
Anything below Gtx260 will not show difference above the 8800gts. Consider this before shelling out money
Edit: If it's for a friend than good to go.
hehe, yap he had a 8600GT 512 DDR2
1 - 8 of 8 Posts
