What HDD's should I get for my rig?
1043 Views 2 Replies 3 Participants Last post by  Miki
So I got my rig below, what hdd's would you guys recommend? I was thinking 2 320gb WD AAKS drives in RAID 0.
I would like to spend like $120 on a couple drives. I really don't need more than 300gb total because the RAID 0 setup will only have my OS, games, progs on it. All my media is stored on my 1tb hdd.
Are those 320gb AAKS drives really good in raid?
Is raid 0 the best raid setup performance wise in price/performance ratio?
1 - 3 of 3 Posts
first choice is this. I know the money issue but you asked for advise and I will give you to straight poop.
Choice 1. 2x SSDs in raid0
http://www.newegg.com/Product/Produc...82E16820233075
Choice 2. 2x WD raptors in raid0
http://www.newegg.com/Product/Produc...82E16822136296
Choice 3. 2x 32mb cache wd 500 @ 7200 rpm.
http://www.newegg.com/Product/Produc...82E16822136320
The third one is in your price range and is 32 mb cache. This compensates for the decrease in motor speed. Plus both of these are a nice little tera-byte. Yum....
They should be perfectly fine bro.
As far as your question about Raid 0, take a look here.
That may answer many of your questions.
1 - 3 of 3 Posts
