What is 1:10 white vinegar to distilled water solution ?
871 Views 10 Replies 9 Participants Last post by  binormalkilla
I want to clean my brand new GTX 360 rad and wanted to know what does 1:10 white vinegar to distilled water solution mean ?
Thank you
1 - 11 of 11 Posts
1:10 ratio means for every 1 unit of vinegar, use 10 units of distilled water
ie...1 ml vinegar, 10 ml water....1 liter vinegar, 10 liters water
Just as it implies. 10 parts water for every part vinegar.
It means that for every unit (Liter, mL, etc) of vinegar, you have to add ten units of water.
Try this:
A 1:10 ratio of corn starch to water and mix. Then try punching it, just try.
Originally Posted by 006 View Post
so 100ml:1000ml will work right ?
Thanks again everyone
yep you got it.
Yeah that will work fine. I'll leave you my cleaning PDF, you need to rinse that out after you clean it, I go into more detail in the PDF.
Originally Posted by Crazy9000
The american school system strikes again.
ROFLMAO
As stated, yes 1:10 is just a ratio for the volume......1L water:10L vinegar, etc.
1 - 11 of 11 Posts
