What is a good ati graphics card
1107 Views 32 Replies 19 Participants Last post by  LiNERROR
I want to play crysis on high and play fsx on very high at 1440X900
1 - 20 of 33 Posts
4850/4870 should be enough.
A 4850 will give good performance but the 4870s are getting really cheap, you can get one for $155 after rebates, I would recommend that for better frame rates and AA.
EDIT: And no a 3850 won't be enough.
Originally Posted by bk7794 View Post
this
Willthisthis be good
You meant 4850? 3850 can't even match 8800GS. Maybe like this and this but I don't know the budget thou.
But it has a fast clock speed.
You meant 4850? 3850 can't even match 8800GS. Maybe like this and this.
okay good point. I might go with the 4830 and oc it ab it. will that be better for crysis on high or better yet the 4850. Will it also play the games of tommarow meaning like the next year
Clockspeed doesn't mean anything if one GPU has way more shaders.
3850's are horrible now.
Get a 4850 or 4870
Here are some numbers. If bugdet is low, go for 4830, Otherwise, get a 4850.
I have a 4850 and it works just fine (look in sig). I can play crysis on high at or around 40-50 FPS <.< And there is almost no lag until you get to assualt harbor.
If you can get your proc to around 3.0 (and it is a C2D, the you will be rather well off).
I vote for a 4850!
okay your reccomending those. If I get the 4830 and oc it to about the same specs of the 4850 would I than be able to play crysis on high or will it do it stock
I have my E5200 at 3.0
No happy card for crysis but 4830 or 4850 consdiers a reasonable performance at that price range. You should be able to push E5200 a bit higher on that ud3r board.
is this okay
A good one.
A good one.
okay thanks. The second 4850 I like because it has only one slot. And also what you mean by no happy card for crysis
Not quite a right word. What I am trying to say, as resolution moves higher, even powerful GPU, it is still struggling.
good point. I actually got my 4550 to play on high and got 20fps. Pretty decent for a 64 bit card. When I get this it will replace the 7200le in my parents pc so aero will work better
1 - 20 of 33 Posts
