1 - 4 of 4 Posts
I need A Moduler Power Supply That can handle all of theses Listed Below
Case: Color Master HAF 912
Motherboard: Gigabyte GA-Z77X-UD3H
CPU: i7 3770k ( I Do plan On overclocking to at least 4.5Ghz or a little Higher)
GPU: MSI Nvida GTX 670 Power Edition ( Might add Another Later on )
RAM: Corsair Vengeance 16GB
SSD: Samsung 830 64GB
Hard Drive: Western Digital Caviar Green 2TB
CPU Cooler: Corsair Hydro Series H100i
Optical Drive: Sony AD-7280S-OB
My Budget is atleast $90 or Lower.
· Premium Member
MicroCenter's PSU selection is a lot worse, with higher prices generally. You're looking for roughly 600W+ to be safe, maybe less if you don't really run full load and don't overclock the 670s much. Unfortunately, their selection around ~650W sucks, and power supplies under that usually would require molex adapters for SLI anyway, so might as well bump up.
Can you stretch to $100? There's the Thermaltake Smart 750W (SP-750M) for $100 before $20 rebate:
http://www.microcenter.com/product/383021/SMART_Series_750_Watt_ATX_Modular_Power_Supply
Or you can get mostly the same thing under Corsair's name (CX750), with downgraded fan and internals and no modular cables, for $85 before $10 rebate:
http://www.microcenter.com/product/399158/CX_Series_CX750_750_Watt_ATX_12V_Power_Supply
1 - 4 of 4 Posts
