What is a safe overclock for a 4550.
697 Views 10 Replies 5 Participants Last post by  bk7794
Right now I got it at 620 and 920 is that okay. Thanks my temps are around 42c 100%load
1 - 11 of 11 Posts
u can go higher im not familiar with the 4550, but 42C is pretty darn cold for a gpu at 100% load.
how high
As far as you can and asl long as you are stable. I got mine to 860Mhz core and 1175Mhz memory.
How much life will it take out of it
A safe overclock would be good temps and stability. As long as your temperatures aren't high on full load and it's stable then you should be ok.
now how can I test stability
ATI Tool
http://www.techpowerup.com/atitool/
1 - 11 of 11 Posts
