What is a safe voltage to run on a E6600
453 Views 4 Replies 4 Participants Last post by  omegablue
Hi guys i have overclocked my E6600 to 3ghz without changing the voltage, cpu-z says that it varies between 1.280 - 1.312. I wouold like to up the speed some more but it crashes loading windows! what would be a safe voltage to use and could you tell me what values that i need to change in the bios, to change the voltage my mobo is a Asrock 4coreN73PV
Thanks in advance
-Ben
1 - 5 of 5 Posts
Thanks in advance
-Ben
anything below 1.5 on vcore
pretty much what ive always gone by. Another thing to consider is if the nuber changes to red in the BIOS it is above Intels spec sheet iirc
with good cooling you can go 1.55v
Thanks guys, thats a great help! however i am not sure on what setting to change in my chipset option for voltage i have -
DRAM - which i have upped to 2.0v for my kingston hyperx ram
VTT Voltage - which is on auto
VDDQ Voltage - also on auto
I dont see vcore voltage any where not even in cpu options, just getting a bit lost
1 - 5 of 5 Posts
