what is the use of it
an what will happen if i use a 4-pin in it, it need 8 pin
this is for
GA-MA785GT-UD3H
athlon 2 240
and no graphic card
only basics to run the PC
can i do it??
Yes you can, with your dual core only one 4 pin(ATX) is really needed anyways. 8pin(EPS) is mainly for quad core CPU's and overclocking(even then 4 pin will probably be enough, it'll just deliver cleaner power, also).
Overclock.net
