1 - 7 of 7 Posts
I read in another thread that is should be disabled, and i got a higher bench score compared to it enabled on a higher clockspeed.
see screenshot, 4ghz beat 4.1ghz in cinebench
other settings are the same.
turbo core = disabled
vcore = 1.37
northbridge = stock
ht = stock
bus speed = stock
I Love this Hobby!
This was an implementation decision made during Microsoft's Windows NT kernel design, and based on our experiences with both processor vendors' hardware, it wasn't considered a "feature" to either company. Of course, it affected Intel in a much different way than AMD. The problem Intel had in Vista was one of power consumption. For every migration, you had to write-combine the Nehalem architecture's L3 cache, which cost power.
This changes with Windows 7 and a feature called ideal core. If a task's needs are being addressed by one core, the operating system will let you stay there. This means two things to Intel: first, you don't use power on the migration, and second, idle cores are able to remain in a C6 state. Purportedly, this migration fix alone will yield an extra 10 to 15 minutes of battery life on Nehalem-based notebooks, though this won't become a major issue until the mobile dual-core Arrandale launches later this year. Perhaps more interesting, though, is that processors without C6 will not realize this gain (including AMD's CPUs)."
Source;
http://www.tomshardware.com/reviews/fx-8150-zambezi-bulldozer-990fx,3043-7.html
If you want maximum performance turn off C1 (help with DPC latency -sound card dont like C1) ,CnQ (i am disabling this since i was using X2 6400+ -it was always dropping the peak performance enabled ) ,APM (to avoid throttling) , C6 (avoid parking ,even though the patches on W7 do this smarter) .
Also turbo core should be turned off as when you are playing with the others enumerated seems to not kick in if ever was (rarely seen it working on my 4100FX with my 970A-UD3 .i suspect the mobo in culprit .
The turbo clock can be considered a safe overclocking shelf.
Of course the CnQ and C6 off means more power consumption if you care about this.
You can gain more performance by setting the HT at 2600 manually if you are lucky to use a board that sets it default ay 2400MT for unknown reasons (as my board does)
Depending on the CPU / APU model, the highest boosted frequency PState usually has a C6-state requirement.
For example on FX-8370 which has 4.0GHz (P0, base), 4.1GHz (Pb1, boost) and 4.3GHz (Pb0, boost) states, the C6-state requirement is set to four. This means that the highest PState (4.3GHz, Pb0) will not activate unless half of the cores are currently in C6 active state.
If you disable C6-state this condition can obviously never be met, and the highest boosted state will never activate.
In this case the CPU will operate at the highest frequency PState which doesn´t have the C6-state requirement (4.1GHz Pb1).
Likewise if you disable APM(Master) feature from the bios, it will essentially disable Turbo.
Killing APM will kill the power management and after that the CPU no longer knows how much power it consumes.
Requirements for Turbo (CPB):
- CPB Enabled
- C6 Enabled
- APM Enabled
Failing to meet any of those will render Turbo either partially or complete useless.
IRC: #amd-overclocking
Could you explain a little more what you mean by "...CPU no longer knows how much power it consumes"? I always thought that the VRMs handled how much power to deliver to the CPU and that the CPU never really "knew" how much power it was or wasn't consuming. Your statement makes me believe that I am totally wrong.
Apologies if my question seems like it's coming from an idiot, but I don't know what I don't know so I thought it was worth asking.
1 - 7 of 7 Posts
