1 - 10 of 10 Posts
Hi all.
What is is CUDA cores and Stream processors? How do they differ?
There's no real difference between CUDA cores and stream processors.They do the job of the old pixel and vertex shaders. There ARE differences between them which is why AMD has 1,000+ on their cards while Nvidia has 512. But they do the same job. Even though they do the same thing they use differant configuations so they are not comparable, 1 CUDA core= 1 Stream processor, but cards at the same price point perform similarly
Climbin' in yo windows
They also are able to compute certain instructions, very well, that previously only the CPU could handle. The result is things like encoding video on the GPU rather than the CPU, leading to much faster transcoding etc.
Reactions: vinton13
Originally Posted by MoBeeJ;14236552
They are the same. Nvidia and ati/amd call them stream processors, but nvidia to difirentiate itself calles them CUDA cores.
IIRC, I read somewhere the SP calculations goes like this ATI 800/5 = 160 stream processors (NVIDIA)
Discussion Starter · #6 ·
So, the more powerful GPU would have more Stream processors/CUDA cores, right?
If clocked the same as the card you are comparing it to. there are a few variables involved but usually yes that is right
Discussion Starter · #8 ·
Right. Wanted to make sure of that. Thanks a lot guys.
Rep'd
Yes , but that's because nvidia uses more expensive , high-clock , high performance shaders while amd uses less expensive / lower performance but more shaders .
That's why you see 3-4x more shaders on amd cards .
The quality is crap though. Even the x264 developer looks down on it.
Their much better for complex mathematical equations that would take a CPU alot more time compute.
1 - 10 of 10 Posts
