1 - 8 of 8 Posts
I'm planning on getting windows 7 ultimate off of newegg and I ran into the OEM version. I was wondering if it would be any different from the regular "full" version. Which one would be better to install on a self-built computer?
"The oem version can only be used once on that system and no tech support from M.S. The retail version can be installed in multiple computers, one at a time. Meaning you can install then deinstall then install in another computer. Plus you can call or email M.S. for tech support."
I stole this from here, and that is pretty much the difference.
Originally Posted by Carey Frisch
OEM versions of Windows 7 are identical to Full License Retail versions except for the following:
- OEM versions do not offer any free Microsoft direct support from Microsoft support personnel
- OEM licenses are tied to the very first computer you install and activate it on
- OEM versions allow all hardware upgrades except for an upgrade to a different model motherboard
- OEM versions cannot be used to directly upgrade from an older Windows operating system
Basically if your only using it for one pc use oem.
Use of this OEM System Builder Channel software is subject to the terms of the Microsoft OEM System Builder License. This software is intended for pre-installation on a new personal computer for resale. This OEM System Builder Channel software requires the assembler to provide end user support for the Windows software and cannot be transferred to another computer once it is installed. To acquire Windows software with support provided by Microsoft please see our full package "Retail" product offerings.
From Newegg
Discussion Starter #8
Looks like I'm getting retail.
1 - 8 of 8 Posts
