What is s/w & h/w over 4g remapping
6012 Views 4 Replies 3 Participants Last post by  rcantec
S/W Dram Over 4G Remapping
H/W Dram Over 4G Remapping
I got new asus mobo and i have noticed these options , can someone please enlighten me what these do. I have two sticks of 1g ram OZ brand. Should i keep it enabled ?
1 - 5 of 5 Posts
The first thing you listed isn't relevant because of your cpu. Because you have a cpu with E0 or higher (yours should be E4 or E6), you would want to Enable the Hardware remapping if your system is using 4 gb of memory or above. For systems without an E0 cpu or higher, they'd have to Enable the Software remapping. Doing so moves the memory block above 4 gb and will allow your OS to use all 4 gb. If you don't enable it, some of those memory addresses are saved for PCI slots. Bottomline, disable both with your current ram.
thank you very much!
confused on your reply can you explain in detail? sccr64472
1 - 5 of 5 Posts
