Originally Posted by brettjv
Either the Asus ARES or the Sapphire 5970 Toxic 4GB.
Of the actual realistic (i.e. semi-affordable) choices, the two best are the 5970, and the GTX480.
PCI-Ex 1.1 16x is not that much of a bottleneck for any card out there, honestly.
But the processor might be. What are you going to get for a CPU?
My thoughts exactly.
However, your choice ultimately comes down to if you think PhysX is worth buying a card for.
Personally, I dont thing PhysX should be a deciding factor in buying a card, So I go with ATI. I see PhysX as 60% Gimmick, 30% Tech that will SOMEDAY be great, and 10% great technology. If in the future PhysX becomes realized and accepted by the mainstream, ill jump back on Nvidia. For now, I use ATI.
I would go with a Sapphire Toxic 5970 4GB ideally, But more reasonably, a Sapphire Toxic 5850 2GB that you OC to 5870 Levels.
Or a Geforce GTX 480.
Once again, to me, Its all about PhysX. Other than that, both are great.
