I have a Samsung p2540h LCD monitor which is 5 years old passed warranty years ago. The stand holding part inside the monitor just recently broken and google research showed it is a design problem, that part would have high chance just break after years of usage. So I buy a copycat of that part from Tao Bao.
The real problem is it is so hard to open this "no screw" monitor. I actually fixed this already but the open monitor process was painful and I broken few "clips" which holded the cover and the back of the monitors. I left a lot of big scratches at the edge of the cover and the back since it takes so much force to open those chips. I was using "no scratches" tool already, if I use screw driver then I may even just break the whole thing.
Here is a similar story which you can see he left scratches, same for me and I broken a lot of internal clips too:
https://www.reddit.com/r/2vgggy/just_repaired_my_lg_screen_by_changing_4/%5B/URL
So my question is how can someone opens this thing up without any scratch or break any clips. I have no idea even if I do it again. I think only stuff in Samsung repair office with a clear manual knowing exactly where are those clips and they have their tools for their monitors then can leave no scratches and nothing break.
I read stuff online and LG service manual shows it should be opened by release those clips at the internal edges which are next to the screen, but then I wonder that way would very easily hurt the screen which is the last thing I would want to happen.
My monitor is working fine with the copycat plastic part now but just there are actually scratches at the back edges and many clips inside are broken, but somehow the back and the cover still can stick together with the clips left.
So may you share your experience or thought? Thanks.
