Yeah that happens when you cool and quiet is enabled. However if you turned it off and it still fluctuates wildly (which i doubt will happen), you might want to check the railings on the PSU.
It is still perfectly acceptable if your voltages sway a bit. Mine is set at 1.42, but because of Vdroop and dynamic voltage, CPU-Z reads my voltages at 1.38-1.39
