since you have 2 CPU's which are apparantly dual-cores with hyper-threading, that's 8 CPU graphs in Task Manager
as for CPU-Z, you should be able to change to the other CPU under the Selection option, it only shows the specs for the 1 on the main tab, 2 cores, 4 threads
