1 - 20 of 45 Posts
this is what i found under mine<br />
<br />
<img src="http://www.overclock.net/gallery/data/500/medium/000_1263.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
not to bad but the thermal grease was ALL dried out and my core temp was idling around 37c at stock<br />
<br />
so i lapped my TT Big Typhoon and removed the IHS to find this<br />
<br />
<img src="http://www.overclock.net/gallery/data/500/000_1262.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
do i get a gold star :V
I did the same. My CPU temps now idle at 26 C. <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> It was a good 7 to 8 degree drop. I can't give you a gold star, but every degree drop of your temp translates into a more killer rig. <img src="/images/smilies/gunner2.gif" border="0" alt="" title="Gunner2" class="inlineimg" />
I did it and nothing broke! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
You got it! Just let us know how much your temps drop. <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Reactions: PaRaDoX
K8V SE Deluxe?
awesome job man<br />
how long did that take you?
Was easy to remove?Maybe Im going to do in my x2 4400.I heard some are solded.
<tr>
<div>
Originally Posted by <strong>alexisd</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1401415#post1401415" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Was easy to remove?Maybe Im going to do in my x2 4400.I heard some are solded.</div>
</td>
</tr>
</table>
</div>I think it is the AM2 ones that are soldered. The 939's are okay though.
<tr>
<div>
Originally Posted by <strong>bdattilo</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1401422#post1401422" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I think it is the AM2 ones that are soldered. The 939's are okay though.</div>
</td>
</tr>
</table>
</div>You think is any drop in temps?
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>The Hundred Gunner</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1401408#post1401408" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">K8V SE Deluxe?</div>
</td>
</tr>
</table>
</div>You know it <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<tr>
<div>
Originally Posted by <strong>thehybridpyro</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1401412#post1401412" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">awesome job man<br />
how long did that take you?</div>
</td>
</tr>
</table>
</div>like 2min to get it out and the IHS off<br />
<tr>
<div>
</div>
</td>
</tr>
</table>
</div><div style="margin:20px; margin-top:5px; ">
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>i been reading up on it and it seems Intels (namely celrons P4's skt 475) are the ones<br />
<br />
<br />
and so far its case temp and its 35c due to the fanless GF4 MX440 OC'd to hell and back
I did a 3700 sandy saturday for a test run the next one coming off is my opty<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
how do you prevent DIE crushing? putting in rubber spacers would probably do the trick<br><br>
or some sort of spacing material
Discussion Starter #14
This is the guide i followed<br><br><a href="http://www.dfi-street.com/forum/showthread.php?t=40207" target="_blank">http://www.dfi-street.com/forum/showthread.php?t=40207</a>
Discussion Starter #15
If you have a good heatsink chances are you will have two/four bolts you tighten down like this Thermaltake Big Typhoon<br><br>
The clip on a stock one is just not made for a exposed die
Layer black electricians tape across 2 ends up to the top height of the die then trim off excess with a pair of scissors..
does the artic 5 silver compound paste end up drying up and makes ur rig hotter?? i thought u apply it , then cools ur system..
Most user feedback and reviews on Arctic 5 claim a 1 to 3 degree temp improvement - sometimes even more. Make sure you use a thin layer of it over the entire CPU or IHS surface you plan on contacting with your heatsink. Also good idea to clean as much as possible the connecting surfaces (with appropriate cleaning material) and lap the heatsink to a mirror shine.<br><br>
There are also reports that the AS5 improves temps after a certain burn-in period as well.
1 - 20 of 45 Posts
