Hi there,
I have slowly been piecing together my audio system. Right now, I just have my amp, but hopefully I'll soon have my speakers, and then a DAC at some point as well.
Cables are an upgrade that I plan to save for later, when I have a bit of money lying around, but seeing as though I'm on an extremely tight budget, buying hi-fi cables right off the bat doesn't make much sense.
Unfortunately, I still need cables. Be it Hi-fi, or just regular old cables, I'm gonna need them in the end. I'm just not sure which kinds my system requires, hence me coming to you for help! biggrin.gif
Int. amp: CA Azur 640A V2 - http://www.cambridgeaudio.com/summar...2%29+amplifier
Not sure yet which speakers I want, but here are the two that I'm looking at:
Monitor Audio Silver RX1 - http://www.monitoraudio.ca/products/...1/your-speaker
Ascend Acoustics Sierra-1 - http://www.ascendacoustics.com/pages...SRM1/srm1.html
DAC: CA DacMagic - http://www.cambridgeaudio.com/summar...Title=DacMagic
This is how the system will go.
Computer > Int Amp > Speakers.
At some point I will upgrade from my computer's Dac to the DacMagic, but for now I'll just be using the onboard audio from my computer.
I also want to be able to hook up my pod to the amp, so for that I'll need an LOD RCA, correct?
That about wraps it up for me. Please remember, I'm asking which cables I need to connect my system. I wouldn't say I'm looking for the bare minimum in quality, I just want something that's cheap and won't die on me for a year or two.
Thanks!
Thanks!
