1 - 5 of 5 Posts
I am looking to replace my piece of crap Antec TP-II 550 watt power supply with something that actually works and runs like it is supposed to. I really don't know what kind of power supply to get exept for the information the OCZ, Ernemax, and PC-POWER AND SUPPLY are good vendors. I know what the type of watts that I need but don't know how much amps on each of the pins that I need. I want to go out and buy a 700 watt OCZ power supply but it only has 36 amps on the +3.3V. Someone I talked to told me that I need at least 38 amps on the +3.3V and I have to agree because I am overclocking and am also looking into buying 2 more gigs of DDR3200 Supertalent ram. I am also running a fully cooled system with 3 80mm. fans, 1 120mm. fan, 1 slot VGA cooler, 1 aftermarket VGA cooler, a TT Big Typhoon VX CPU fan. I want a power supply that is going supply all these needs and have some left so that I can do some modifications later this year or early into next. Does it matter what amps I have for the +3.3V and the others as long as there is plenty of power(watts)?
<div>Originally Posted by <strong>droby1987</strong> <a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1398490#post1398490"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I am looking to replace my piece of crap Antec TP-II 550 watt power supply with something that actually works and runs like it is supposed to. I really don't know what kind of power supply to get exept for the information the OCZ, Ernemax, and PC-POWER AND SUPPLY are good vendors. I know what the type of watts that I need but don't know how much amps on each of the pins that I need. I want to go out and buy a 700 watt OCZ power supply but it only has 36 amps on the +3.3V. Someone I talked to told me that I need at least 38 amps on the +3.3V and I have to agree because I am overclocking and am also looking into buying 2 more gigs of DDR3200 Supertalent ram. I am also running a fully cooled system with 3 80mm. fans, 1 120mm. fan, 1 slot VGA cooler, 1 aftermarket VGA cooler, a TT Big Typhoon VX CPU fan. I want a power supply that is going supply all these needs and have some left so that I can do some modifications later this year or early into next. Does it matter what amps I have for the +3.3V and the others as long as there is plenty of power(watts)?</div>
</td>
</tr></table></div>
The +3.3v and +5v rails don't matter as much as the 12v rail, whoever told you that you need 38amps on the +3.3v rail is flat out wrong<br><br>
What is your budget?
Discussion Starter #4
My budget is around $100-$200 for a power supply. I need something that will allow me to upgrade without any worries of being without enough power.
The PSU Nasgul mentioned is very good and fits in your budget<br><br>
PC Power & Cooling Silencer 750 $200<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817703006" target="_blank">http://www.newegg.com/Product/Produc...82E16817703006</a>
1 - 5 of 5 Posts
