What kind of safe overclock can I get with the 4850?
1884 Views 4 Replies 4 Participants Last post by  Eccentric
I just got my DuOrb today and installed it.
I have it overclocked to 700/1100 atm with CCC. But I can't go over 700 GPU Clock
My temps are 35-36 idle and 59-60 underload with the overclock.
1 - 5 of 5 Posts
I've got a 700/1120 OC... never mind my sig. As soon as I update my sig, the OC will not be stable... hence not updating it.
700/1100 is a good OC with stock volts. With Rivatuner, you can probably hit higher than 700 core...
I can do 730 for benching with 1090 on the mem.
Oh ok, so 700/1100 is a pretty good overclock?
I plan on keeping it at that all the time, is that ok?
How can I make CCC load those settings everytime I turn on my computer?
I'm at 710/1100 at the moment and reach around 58 C at load. Around those speeds are the limit for the 4850 until you raise the voltage for the card through overdrive or through a volt mod.
1 - 5 of 5 Posts
