1 - 4 of 4 Posts
I need a material to use as a buffer between the glass & the desk and a also act as a seal around the lip.
I'm using some (I think) closed foam strips I found at home depots window & door section and while it holds its shape, it's still too thick at almost a 1/2"
I'm looking for something maybe 1/8" - 1/4" & 1.5" wide that will seal and not totally flatten out/smoosh under the weight of the glass.
Here's what I'm using now, it's great as far as holding it's shape & the weight of the glass, but it's just way too thick, but nice & wide:
Overclock Failed...
Good advice, buy my desk is all aluminum and I definitely want to seal it off to prevent as much dust getting into my system as I can.
you can get all sorts of sticky back foam tape, you'll find it in all sorts of widths and maybe 1/8th inch thick
quick search on amazon or ebay etc
1 - 4 of 4 Posts
