1 - 12 of 12 Posts
it's kinda loud for me. it comes from my computer case inside.
Is it possible that it comes from my ssd? i have a samsung 850 pro ssd
don't think so, an SSD does not have moving parts, is better if you open the case and check exactly where is coming from
Discussion Starter #7
it doesnt sound like sth stuck but like electric current sound.
i opened the case all the time cuz i bought corsair h80i and its a bit bigger than i thought.
DTR Enthusiast
Sounds like coil whine to me. I had to really crank up my sound system to hear it though. Doesnt sound *too* bad of a whine, compared to others. Nothing you can do about it, just gotta live with it.
Most likely either the PSU or GPU coil whine, completely harmless and no way to fix other than replacing the part.
Aint da way it used to be
In some instances, you can paint the coat the offending part with nail polish or other resins, but I have never tried it, and don't neccesarily recommend it, its just something I've heard of.
1 - 12 of 12 Posts
