Status
Not open for further replies.
1 - 2 of 2 Posts
I want to choose a power supply for my PC ....
there is 2 type of good (solid) power supply in our city
1. Thermaltake TR2 800W http://www.thermaltake.com/products-model.aspx?id=C_00001658
2. Gigabyte ODIN 720 http://www.gigabyte.com/products/product-page.aspx?pid=3045#kf
My casing will be Thermaltake Overseer RX-I http://www.thermaltake.com.au/products-model.aspx?id=C_00001803
And i will insert all Fans
1. Front (intake) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA)
2. Top (exhaust) : 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA)
3. Rear (exhaust) : 120 x 120 x 25 mm Turbo Fan (1000rpm,16dBA)
4. Side (intake) : 200 x 200 x 30 mm LED Fan
5. Bottom (intake) : 120 x 120 x 25 mm LED fan
And water cooling is Thermaltake bigwater A80 ..... All my my Equipments are..........
Processor : :Core i5 2500K
Motherboard : : ASUS Maximus IV Gene Z Gen 3
Graphic Card : : ASUS ENGTX560 DC/2DI/1G/DDR5
Memory : : CORSAIR vengeance 8GB (2X4GB) (need 2 6-pin ports)
HDD : : 500 GB
SSD : : 1 SSD (may be 32 GB or 64 GB)(for Intel Smart response technology)
ODD : : 1 DVD RW
Cooling System : : Thermaltake bigwater A80
Casing : : Thermaltake Overseer RX-I with 5 fans and 2 UV lights
Please Help me to choose Best PSU
HDD : : 500 GB
ODD : : 1 DVD RW
Your system would run perfectly fine on a solid 450W PSU, the two units you're looking at are far too large.. link the shop/s you'll be buying from and your budget in the local currency.
Of the two you linked the TR2 800W is by far the better choice.
1 - 2 of 2 Posts
Status
