1 - 20 of 26 Posts
Right, I've narrowed it down to these two:-If there are any others that are under £34 (and NOT from New-but only for the usa-egg) then could you please add them on here.
Thanks.
I dont know really what you need power wise but I am getting a 550 watt sumbeam nuuo. The efficiency isnt the highest but its modular and pretty
Discussion Starter #4
Originally Posted by boredom View Post
Neither
You'll need to spend a bit more if you want a quality PSU
What would you recommend, I am VERY strapped for cash, so something okay and cheap will get me through about 3 months, then I'd get myself a Hiper Type R.
Discussion Starter #7
Well everything in my sig apart from the monitor.
Originally Posted by Chozart View Post
What does it need to power?
and stop recommending the NUUO... he needs something cheap.
The NUUO IS cheap... How cheap can you get...
Discussion Starter #9
I think (if no more suggestions come up) I'm gonna go with the Xclio 500W one.
Discussion Starter #10
Do you have any links?
The NUUO is not *that* cheap here in the US... Aroudn $75... for a decent, yet inefficience PSU, that delivers 32A on the 12V rails. In short, it's not on my list of recommendations, esp. when a few members here had their fail.
I can find an FSP 450W PSU here for $51.50 delivering 29A on the 12V rails... not to mention the 500W Hipro, which is below $40, and is more than half decent.
Ok.. enough off topic talk... hold on on the order.. I will poke around a bit. You don't need a high Watt monster.. I'll be back
Discussion Starter #13
I need one that is over 450W AT LEAST because the GPU and CPU are gonna drain the power when I start OCing.
Discussion Starter #15
Oh, I'm not ordering for another 3 weeks, so, yeah. Thanks though Chozart.
Discussion Starter #16
450w FSP ATX-450PNF £47.78 Inc VAT
http://www.scan.co.uk/Products/Produ...oductID=468727
Too much, It needs to be under £37, if not lower. The last PSU I had with my old P4 was a 500W that cost me £7 brand new!! Lol. It did the job (only just) though. Good times, good times...
Discussion Starter #19
Hmm. Off topic, but almost at 1000 Rep Chozart, 1 point thanks to me. You know what your talking about (stupid ClaytonCallihan trying to make me spend my arms and legs! I need them)
1 - 20 of 26 Posts
