1 - 20 of 27 Posts
Hello
So baiscally im buildign a new PC and im going to have:
CPU:Intel Core i7-980X Extreme Edition
http://www.newegg.com/Product/Produc...82E16819115223
CPU(cooler):Scythe Ninja 3 SCNJ-3000 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Produc...82E16835185147
GPU:ZOTAC AMP! ZT-40102-10P GeForce GTX 480 (Fermi) X2 SLI
http://www.newegg.com/Product/Produc...82E16814500166
MB:ASUS Rampage III Formula LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131666
RAM:CORSAIR DOMINATOR-GT 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000
http://www.newegg.com/Product/Produc...82E16820145318
HDD:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...82E16822152185
SSD:Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Produc...82E16820148348
CD/DVD:G Black 24X DVD+R 8X
http://www.newegg.com/Product/Produc...82E16827136177
CASE:COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811119225
MONITOR:ViewSonic X Series VX2739WM 27" 1ms HDMI Full HD 1080p Widescreen LCD Monitor w/ 4 port USB-hub300 cd/m2 DC 100,000:1(1200:1) Built-in Speakers
http://www.newegg.com/Product/Produc...82E16824116441
So im not really sure about the PSU,But i had few of them on my mind:
KINGWIN Lazer LZ-1000w 87%
http://www.newegg.com/Product/Produc...82E16817121068
or
XION Power Real XON-1100w 85%
http://www.newegg.com/Product/Produc...82E16817190025
Please let me know your thoughts and just little thing on the side the GPUs are already overclocked.
AMD Overclocker
The hx1000 is outdated and overpriced. For your system, a good 850w is all you need. Heck, I bet you could even run it off a 750w.
Go for the corsair 850hx.
850 would be cutting it close to its max, since the 480s will need at least 250 watts, that'
s if they are run stock speeds. Overclocked i7 could use up to 200 watts, or more, depending on the overclock. I would go for nothing less than 1000 watts. Look at the Enermax 1050 or 1250, Silverstone 1200 or even 1000.
Outdated? How so? It'd still say it's an excellent PSU
OT: I wouldn't touch a 1000+W PSU lower than $190
how about Enermax Revolution 1050W? its an awesome unit that will handle everything OC'd to the max!
abs 1050 same unit $86 cheaper
The tpq is also ok and the seasonic x-1000 also out soon
A GOOD 1000w will do the job just right with a bit of overclocking. If you want to overclock a lot and want a water cooling setup, go for a 1200w. Corsair hx1000w is a great psu for you. Never get an xion. They are crap. Like one post said, don't buy a psu under $200. You want to have a quality psu. Another psu I'll recomend is the antec 1000w. If you want more upgradability, go for an antec 1200w or a corsair ax1200w.
I love my antec TPQ 1200w OC edition. I don't know if you can get the OC edition where you are, but the normal non OC edition is pretty much the same thing, though there are less built in cords for your PCI cards, and there aren't any adjustment knobs on it.
So does that make my PSU lower quality because I got it for $45?
Or for a rig with SLI 480's and a 1000w PSU, the Tuniq Ripper 1000w is $110 shipped and it is better than a lot of PSU's that are $200+.
Well can your psu run an i7 and gtx 480s in sli?
No but that Tuniq ripper can. You can get the Ripper shipped for $59 shipped.
1 - 20 of 27 Posts
