1 - 20 of 20 Posts
Well, what resolution is 480p? 1280x1024?
You should have Googled it.
720x480
The three digit number in all resolution designations denotes the number of pixels on the Y axis.
480p = 720x480
720p = 1280x720
1080p = 1920x1080
the 'p' denotes a progressive scan at 60 frames per second.
Pink Freud
720x480 pixels
Reactions: vinton13
720x480
480p = 720x480
720p = 1280x720
1080p = 1920x1080
Google? I forgot about that site after finding OCN. :\\
Can also be 640:480 in 4:3, but is generally considered 720:480 because of the letterbox DVD format.
Pink Freud
720x480
nvm.. I see you edited that a lot....... lost count...
And I was just about to quote you for being so anal retentive about editing... and now you edited it. Oh the irony.
Discussion Starter · #11 ·
Originally Posted by eseb1 View Post
Wow, this thread fails.
Why would you possibly think 480P was 1280x1024?!?!?!?
I don't know, maybe, I don't know?
Coming down on someone for not knowing something is a very ignorant statement to make.
It's always better to have compassion and help than to ridicule for less knowledge.
you didn't take a hint from the number 480?
Originally Posted by muels7
Well what about 480i? Are 480i and 480p the same resolution?
480i = 640x480
480p = 720x480
Discussion Starter · #16 ·
Nope. Even if I did. 480x??? or ???x480?
Originally Posted by CryWin View Post
480i = 640x480
480p = 720x480
No no and no.
I and P are the same resolution. Its all up to TV and the quality of TV to handle the incoming source.
One signal is Interlaced...the other is Progressive Scan. Same res, different ways of displaying it to you. (With PS obviously being superior as giving you a full meshed frame at a time whereas Interlaced gives you grids of vertical lines)
Prolly vaping...
wow...
hurr and durr to you sir.
Originally Posted by crywin
480i = 640x480
480p = 720x480
Originally Posted by ryanrenolds08
no no and no.
I and p are the same resolution. Its all up to tv and the quality of tv to handle the incoming source.
one signal is interlaced...the other is progressive scan. Same res, different ways of displaying it to you. (with ps obviously being superior as giving you a full meshed frame at a time whereas interlaced gives you grids of vertical lines)
qft
1 - 20 of 20 Posts
