1 - 8 of 8 Posts
Here are some motherboard functions... for the hardware monitor on my board.
I have an asus m4a87td usb 3
THose settigns on the bios arent mine. Thats a sample photo to show u the functions
http://imageshack.us/photo/my-images...aitweaker.png/
Cpu q fan function: e/d
cpu q-fan mode: silent, manual, turbo, standard
cpu fan speed low limit: 500 rpm 400 300 200 100 ignored
cpu fan max duty cycle: 20 30 40 50 60 70 80 90 100
cpu fan min duty cycle: 0 10 20 30 40 50 60 70 80 90 100
cpu config:
microcude updation: e/d
secure virtual machine mode: e/d
cool n quiet: e/d
asus core unlocked: e/d
c1e support: e/d
cpu frequency and so on...
I tried to go 3.75 already and my load temps are 63
stable 37 celcius of course.
core voltage 1.14v
any other info u want ask me!
btw i have an corsair h50 water cooled cpu cooler
it throttles at low load and goes up to 1.44 under stress
Too much, maximum safe temperature is 62C for your CPU. Your cooler should be doing better. What's your ambient temperature? Have you cleaned your case recently?
Watercooler
Your Core voltage is 1.14V? Also with such high temps have you tried reseating?
Make sure the H50 pump is plugged into a fan slot
Originally Posted by anthony224847;14247853
Sorry guys. Here is the new results of my overclock
Now help me out
http://tinypic.com/r/1xxg20/7
I can't see your pic because my work filters it, but make sure you're overclocking your cpu-nb if you're looking for actual performance gains. It's more important than cpu speed on your chip for fps.
1 - 8 of 8 Posts
