what should i get for my cosmos s
588 Views 11 Replies 9 Participants Last post by  SamTheJarvis
hey all, i'm just so frustrated. i have $50 to spend on my pc and i'm getting a cosmos s soon so i want some little accessory. trouble is i dont know what i should spend the $$$ on. any ideas/suggestions? something very useful and worth it.
1 - 12 of 12 Posts
Get a decent CPU cooler. Mugen 2 or a Xigmatek s1283 and assorted copies would be a good choice.
Maybe a Hotswap drive, if you're into that sort of thing, and 4 sets of molex LED lights, 2 shining in the way, one out of the extra fan bay, and one at the top left, behind the mobo, gives a nice glow. Same with cathodes, however you'd only need 2.
Hope that helped.
4GB of ram?
Cooler. Most definitely.
thanks. yeah a cooler was one of my considerations. thanks guys. it's either cooler or RAM....i can get cathodes for free from a friend but it's not too important to me. i however need a short cooler for the cosmos because u need to remove the fan for the big ones and i don't want to do that.
any suggestions on coolers?
maybe get the side window they provide for the case. That way you can fit a bigger cooler. That will be again at the expense of your side case fan but in exchange you get a view. =)
Take measurements. There's a Kingwin Xigmatek HDT copy cat that's a bit shorter than much any other 120mm tower cooler.
thanks will check it out
it suuuuuure does, lol.
1 - 12 of 12 Posts
