What should I upgrade
252 Views 8 Replies 6 Participants Last post by  -iceblade^
Graphics card: Saphire
Cpu Cooler: not known yet probably xigmatek dk
Power Supply: Cooler Master or BFG.
1 - 9 of 9 Posts
There are a lot of ways to go. What are you looking to do? A little info will yield more positive results.
yeah what the man said, and how much money do u have to spend?
Well, if you look into a bigger power supply then your range of future upgrades widens substantially.
lol, consider getting a case...
Antec 300 could be a good place to start.
yeah. I wasn't looking into a case too much. I might get a decent psu this april break. Than a cpu cooler.
not great
antec or corsair are good.
ps the gpu you linked is old and expensive. get the updated version for cheaper at newegg. you can probably get a non sapphire 4850 for even cheaper
http://www.newegg.com/Product/Produc...82E16814102824
1 - 9 of 9 Posts
