1 - 3 of 3 Posts
My Hyper48 will be coming to the shop tomorrow (I do computer building/servicing/networking). I'll be the first to admit when I don't know something. I haven't had to deal with thermal pastes since they started putting the heat transfer pads on heatsinks... From what I've seen on the CM website the thermal paste that comes with it doesn't look that great. So would I be better off using their paste or some dielectric grease until I get some AS5?
EDIT:
Nevermind...
Their paste will work fine....if you really want to go buy something, go to radioshcack and get some of their TIM...it's decent IMO
Thank you for the reply but I already figured it out... Hence the edit. I'm just going to use the stuff that came with it until I bother to get some AS5.
It's weird though... It's different than the pictures I saw online. The pictures showed two pipes next to each other on opposite sides. This thing has all four on the same side.
1 - 3 of 3 Posts
