1 - 6 of 6 Posts
im running a e6400 dual core and using the motherboard as u can see in my system specs i was just wondering should i get this fan <a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=106998" target="_blank">http://umart.net/au/product_info.php...ucts_id=106998</a> or this <a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=103877" target="_blank">http://umart.net/au/product_info.php...ucts_id=103877</a> i just want the better one as i want my comp to stay as cool as possible or possibly even this <a href="http://umart.net/au/product_info.php?cPath=21_108_373&products_id=102304" target="_blank">http://umart.net/au/product_info.php...ucts_id=102304</a> whatever one u guys recommend please tell me why and what product out of the 3 would keep my cpu the coolest as possible, cheers
well the zalman is ok but its not as good as some and definately stay away from the gigabyte watercooler. If you wanna watercool do it right. I would suggest the thermaltake Big Typhoon it seems to be the best out there.<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106061" target="_blank">http://www.newegg.com/Product/Produc...82E16835106061</a>
Ya, as the poster above suggested, get the Big Typhoon (link below). Not only is it cheaper, but it should cool better as well.<br />
<br />
<a href="http://umart.net/au/product_info.php?cPath=108_367&products_id=101448" target="_blank">http://umart.net/au/product_info.php...ucts_id=101448</a>
The first two links don't appear to be available.<br />
<br />
Anyway the TT BT is better. I've owned both.<br />
<br />
How high do you want to overclock? Water may be your only option if you really want to crank it up.
if your only looking for about 2.5 then the BT is the way to go. you'll get good temps and wont have to drop the extra cash on water.
1 - 6 of 6 Posts
