What software for my Audigy ZS 2?
367 Views 5 Replies 5 Participants Last post by  Demented
Hey all, i just bought an Audigy ZS 2 from a fellow OCN member without and discs or manuals, and I'm wondering what software/mods i should install for this card. I only have the drivers from the site.
Thanks, and REP+ for good answers
1 - 6 of 6 Posts
I have the x-fi drivers so it turns the card into an x-fi extreme audio and i have the software for the x-fi utility.
Heres the thread: http://www.overclock.net/sound-cards...ur-audigy.html
The Audigy SE/4 are nothing like the Audigy 2 Series cards. While the SE/4 share the same hardware as the X-Fi xtreme audio card that's the only X-Fi card they share any similarities with. The X-Fi features on the Xtreme Audio card are all software based and no additional hardware acceleration takes place.
That being said you cannot use the same driver for you're Audigy 2 ZS. I have the exact same card and use the Daniel K. drivers. A little harder to find now but search around and you'll find em. Look for SBAX_PCDVT_LB_2_15_0004EQ
by Daneil K. Works great
http://kxproject.lugosoft.com/
best drivers for it
best drivers for it
For XP yes. Unless I'm missing something the kx drivers won't work in Vista.
I have those drivers, and tried them, but while I still have sounds, none of the other things like the EQ or anything didn't work. Was there something I did wrong? perhaps you can help me make them work?
1 - 6 of 6 Posts
