1 - 9 of 9 Posts
Just upgraded to Win7 x64 and have noticed that my FPS in BC2 hovers around 40-45FPS with all settings maxed and 4xAA, with 1360x768 resolution. In XP 32 bit I had around 55FPS+ constantly. Could it possibly be my video drivers? I have the 258.96 WHQL drivers. Thanks.
Discussion Starter #6
i can definitely tell the difference, it just gets choppy. Is there any part of my system that could be bottle necking?
Originally Posted by ulawe View Post
If it's above 30FPS you wouldnt tell the difference.
some people can actually tell the difference while i dont notice the dif between 60 constant and 90 constant i do notice dips from 90 to 60and then back again
nothing is bottlenecking but remember BC2 is a very well known game with sli or CF problems
Lol. Just lol.
BC2 is pretty processor-heavy. I saw a big (20%ish) performance boost from unlocking my CPU to a quad, and another smaller boost from OCing. BC2 takes advantage of 4 cores.
Something is always bottlenecking, in any game, on any PC or config.
1 - 9 of 9 Posts
