1 - 13 of 13 Posts
professional curmudgeon
connecting printers, scanners and other peripherals.
It's a USB3.0 USB-A to USB-B, also used for docking stations / HDD enclosures / NAS.
Reactions: looniam
Thanks. Is it the same like connecting to motherboard USB ports ?
the A type goes to the back/front panel and the type B goes to the device.
motherboard headers for usb 2/3 are: though there are mobos with the C-type as a feature.
newer C type:
Reactions: Welliam
Discussion Starter #6
Sorry I dont understand. This cable come with the monitor and the monitor has Type B and I connect Type A to the motherboard ?
AH.
you connect the C type to the back panel: (or front panel on your case that is connected to the mobo)
what you can do is use that cable to connect the USB ports from the monitor to the computer (back or front case)
then you can plug in your keyboard and mouse to the monitor (or anything else) instead of the back/front of the computer case.
"USB pass through" :thumb:
Edit:
seems you got it as i was hunting a pic. :)
Facepalm
Hi
What this usb cable used for ?
One of my flash programmers has this plug.
My Brook Universal Fighting Board (arcade fighting game things) has this plug also.
9 Cans of Ravioli
it's also what the vast majority of monitors with an integrated USB hub use.
and it needs to die, Type-C all the things :D
woot
dacs often use type a too
1 - 13 of 13 Posts
