What to do after 1600fsb?
718 Views 10 Replies 6 Participants Last post by  Carlitos714
Well for right now I am stressing my Q9550 at 3.4ghz. The Bus speeds at 1600fsb which I know is the wall for my motherboard. If I go beyond 1600fsb what do I risk? Anything I need to know?
Also if you can look at my temps, 58 (1) 53 (2) 52(3) 53 (4)
Thanks OCN
1 - 11 of 11 Posts
More heat, just make sure the Northbridge is well cooled.
The memory is not a limiting factor as it should be, in thory, running at 800MHz.
Those temps seem pretty good, are they load or idle temps?
you won't know til you find out
keep overclocking... i'm sure your q9550 is hungry for 4ghz
load temps. I need some new ram sticks. For speed and for memory. Alright What else will need to be done after 1600fsb?
Well depends if your mobo can take it, if not it will just rester last known good configuration, end of.
i have seen these boards go past 1600fsb
The UD3R motherboard can push quads past 530 FSB (2120 QDR). So 400 FSB (1600 QDR) is far from its limit.
really?!? awesome!!! Thanks so much. Will everything hold out to 4ghz 24/7?
Check out the EP45-UD3P (the R OCs the same, but only has 1 PCI-E slot).
http://www.overclock.net/intel-mothe...ers-guide.html
I've seen a lot of 24/7 OCs ~515 FSB with quads.
wow. Never thought about going to that thread. Thanks Rep+
crank up that fsb!!!
1 - 11 of 11 Posts
