Just a quick summary.
Ordered a HDT-S1283, (tried to) install around 10 times, all went wrong (1mm air gap between CPU & heatsink).
The new HSF backplate will arive this week (counting from sunday, today, onwards), and should arrive thursday or so.
To install the HSF for the first time I had applied a generous amount of grease, and spread it with a little piece of cardboard mixed with plastic (a typical thin wall of a shoe box). I used the two lines method, and installed the HSF quite firmly. Although I 'almost' bent my motherboard several times, it's in perfect conditions, ignoring the slightly twisted heatsink fins of the motherboard and the HSF, too ('bent' a few, very slightly, so it doesn't matter, does it ?).
After some time I gave up and ordered the blackplate for 30 bucks. Also, it's literally impossible to get one from the local market, and had to be ordered without a choice. I have applied the stock fan since then, and it keeps around 50~55º idle (damn that's high) and reaches around 65ºC at load (ambient temps shouldn't surpass 35ºC, say 28ºC~33ºC).
My question now is what endurance does the grease have ?
1.) It's been almost 2 weeks, and I play a lot, so the CPU can be easily said to be at load for 4 hours straight, maybe more, at 65ºC.
2.) After the condition 1.), has the stock grease (that comes with the xigmatek HSF) dried already ? Or is it still moist and I can reapply the 'new' HSF once again without reapplying 'special' (since I ran out of the default grease that came with the Xiggy) grease ?
3.) In the case that the grease is already dry (on the CPU), how about the grease that is on the HSF ? (90% sure it's still wet).
4.) Either 2.) or 3.), should I remove the 'old' grease first whether it's wet or dry ? Or can I keep the old one, regardless of its condition ?
5.) How to remove it in both conditions (wet HSF, 'dry' (if it is dry, I don't know) CPU) ? Can it be done with 'home made' materials ? Say, I wouldn't like to buy a TX-2 or whatever for 40US$ to remove the grease and then buy the AS-5 for 20US$ :|.
Thanks
