Well I am just wondering if that would net me any more points, they are set to low right now but is there any harm in setting them to normal?
Originally Posted by MadCatMk2 ![]() Ok seriously, setting priorities with other programs in [email protected] is for the last time, unnecessary. If you're using the GPU tray version, go to the advanced tab and pick the second option. If you're using the cmd version run it with -configonly and you will eventually be questioned about the priority: Idle, or Low; idle is the lowest, low is one step above that. |
