I am just wondering what tool you would use to remove the snap ring on the fan unless it is called something different.
I would like to know the right tool.
Thanks
Thanks
Yeah but I want an actual tool.
Are they similar to these
the bit size is is fine but i am having size issue where the metal is bigger then the bit
Not really. Those don't appear to come with more than one set of tips whereas the Hi-Techs come with 5 types. I've encountered some rings where only 1-2 of the tips would even fit.Originally Posted by Juggalo23451
http://www.homedepot.com/p/Channellock-8-in-Retaining-Ring-Pliers-927/100348008
I used a pair of these when I painted my GTs. They worked great. I've also used the probes from my multimeter.
