1 - 3 of 3 Posts
Hi. Can someone help me identify this type of fan connector and if an adapter is available for a standard 3 pin fan connector to this? Thanks.
Edit: By standard 3 pin fan connector, i mean this:
I've never seen a connector like that before, and couldn't find any adapters, but you should be able to just take the connector and pins off and replace them.
That doesn't seem to be a standard pc type connector. Almost like I have seen this connector before but want to say on wireless 2.4ghz phone batteries or something else.
What are you trying to do? Easiest thing will probably be to cut and solder the wires to the correct connector you need. The more hardcore approach would be to cut and crimp on the correct pins then insert them into the connector you need but thats a lot more hassle than its usually worth.
1 - 3 of 3 Posts
