1 - 11 of 11 Posts
It all depends on the chip, just start at a high vcore (1.3v) and then keep lowering it until you lose stability, stay at the lowest stable voltage.
When I say the chip I DON'T mean the fact that it's an i7 930, some chips will do high clocks/low voltages, some will not.
Senior Member
For a stable 3.5GHz 1.25 would be enough.
More than enough if you ask me. 1.25v cuts it for 4GHz alot of the time.
Discussion Starter #9
Originally Posted by SecrtAgentMan View Post
Looks okay there, have you ran P95/Linx or anything else to stress test?
yea i ran p95, it was stable
how long did you run it? most people like to run for at least a few hours to make sure. realistically though, you're probably good. as others have said, a lot of i7s can go higher than 3.5 at that same vcore and be perfectly stable.
Discussion Starter #11
Not too long, ill run it all day tommorow
1 - 11 of 11 Posts
