1 - 20 of 20 Posts
and yes i used search like always it hates me im sure its me being a idiot and useing wrong search terms i just used 5 ghz and fx.so if some one can point me in right direction for fx voltage at 5 ghz id sure be happy
It varies on every chip, and the majority won't hit 5GHz on safe voltage.
Discussion Starter #5
dang i just wanted to say i had a chip run at 5 ghz but i sure dont want to blow it up she is stable at 4.1 at 1.35 volts
62C and 1.55v is thuban. I have seen people run hotter, but I would not pass 1.50v myself or 62C. I think that should slow down any degradation from the oc. What are you using the chip for mainly?
Aww, stop posting less than 5GHz. Come on now, you can do this
1 - 20 of 20 Posts
