1 - 5 of 5 Posts
As you can see the caps are in the way on both sides of the chip only allowing a small portion of the block to touch the cpu.
The top left screw number was stripped so I had to remove it with a bolt cutter.
First off, I'll buy that H60 off you (if you're in the US and want a fair price for it), because I've been wanting one to try and mod onto my 470 graphics card.
Secondly, I think the Antec Kuhler, or the H50 is the smallest footprint as far as the surface going to the board, but I don't know if that would be small enough even. If they aren't, you may have to go for a full water cooling loop and get something like http://www.koolance.com/water-cooling/product_info.php?product_id=2030 that Koolance claims will fit that board, or check out the list: http://www.coolingconfigurator.com/step1 after you put in your model of MoBo. The ones listed as "physical" are known to work on that board.
I was looking to go full water cooling loop. Might as well have a case designed for full water cooling Corsair 650D
The second link to match to my mobo does not have my mobo. My mobo is rev 1.0 and they have rev 1.6.
I would sell the H60 to you but its well under 30 days and I would think CompUSA would take it back or I would have to RMA to Corsair.
Looking at the socket area of rev 1 vs 1.6 the caps are a slightly smaller diameter on 1.6 but they look to be the same height and the distance to the socket from the caps on both side has changed by ~0.1" Should be close enough to be compatible.
And if they don't take the return / RMA, due to you having to cut it, pm me.
1 - 5 of 5 Posts
