What watt on the power supply to get?
763 Views 15 Replies 10 Participants Last post by  BlackOmega
Alright, how does this work, i'm looking at a i7 920, which requires 130W and a GTX 275 which requires 550W
http://www.newegg.com/Product/Produc...-475-_-Product
Do i add the 130W + 550W = 680W ?
Is this power supply sufficient? It's 600W
http://www.newegg.com/Product/Produc...20na-_-na-_-na
Thanks!
1 - 16 of 16 Posts
Can you fit this one into your budget? It's just a little bit more expensive, but it will power your system well.
http://www.newegg.com/Product/Produc...82E16817139005
This.... The corsair is a much better power supply....IMHO
Is it just for teh 50 watts more or what? and thanks for your reply.
No, wattage ratings are meaningless if you don't look at the rest of the claim. For instance, is the 600 watt peak or sustained? Is it at real world temperatures or taken in an unrealistic freezer? There are 500 watt power supplies out there that can easily outperform some "700 watt" power supplies. There simply isn't the regulation to keep the claims on a level playing field. Audio is in the same situation. Ever seen a $10 500 watt amplifier that weighs like 1 lb?
Oh alright, thanks a lot!
Wait... a GTX 275 doesn't require 550W! It pulls like 160W while gaming, max.
You could power an i7 system with a single GTX 275 on a decent 450W power supply.
If you're not going to upgrade to dual cards at any point, I'd probably get something like a VX550 or a TruePower New 550W, both are more than enough for your rig.
That 650w Corsair should be sufficient although a good 750w unit would be recommended if you ever do decide to go SLI. Not to mention it would give you the headroom you need in case you decide to add another HDD or 2 for RAID, or you add a lot of fans, a sound card, etc.etc.
I'd be happy running SLi GTX 275s on a 650W power supply. The only trouble is that most of them don't have enough power connectors, except the TP-650.
all i have to say is dont be afraid to spend a little more on the power supply when thinking ahead like if our gonna SLI/Crossfire down the road. cause im looking for the same thing, a GOOD Power supply that will last me a few years...i just dont have any money....
well its important that you have enough on your 12v rail just a little tip
Pretty sweet deal on this power supply. High efficiency. Good brand.
http://www.newegg.com/Product/Produc...82E16817176002
Depends on the power supply. On a REALLY high quality unit, I most definitely wouldn't have any issues with that either (depending on the rest of the rig). However, multi-rail or lower amp unit, I would most definitely not.
Like with your PSU, I would not recommend running 2 275's with that. While sure it'll run it, and could possibly do so for quite some time. However, it'll be running most of the time at a much higher load therefore becoming more inefficient, and you'd wind up actually using more power than if you just had used a bigger PSU.
Not to mention, it could also affect your overclock due to power surges within the system when certain peripherals are engaged and increased ripple (poor input signal). Aside from that some motherboards manufacturers recommend a minimum of 400w just for the board itself.
All in all you're better served by getting a larger PSU. It'll run cooler, more efficiently and provide a "cleaner" input signal.
Corsair 650 TX $70 after MIR and it has the same power stats as the HX. Only difference that I can see between the 2 is that the HX is bronze certified and the TX is plus certified.
I'd still get a 750 over that though, like this COrsair 750 TX.
1 - 16 of 16 Posts
