1 - 13 of 13 Posts
If I plan to move from my pair of 5770, to 2x 5870 what kind of power supply i need? Let say i switch to i7 too...
I am looking for something that will do that but not too overpowered... like I dont want to throw my money around.
This is all hypothetical just doing some researching around for a friend.
Dont take my word for it but I've read that 5870s can be run on a minimum of 750 (on an overclocked i7 system)
I'm running an 850w corsair... going to be getting my second 5870 sometime later next week. Lets see
dont know intel, does i7 pull much more than a 955? with just 955 u are fine i would say...i ran 2 4850x2 with a similiar PSU, and that is a lot for power consumption... 1k watt is recomended for each 4850x2. and 5870 say that 600 is recommended for a CF
ATI Radeon™ HD 5870 System Requirements
PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
Minimum 1GB of system memory
Installation software requires CD-ROM drive
DVD playback requires DVD drive
Blu-ray™ playback requires Blu-ray drive
For an ATI CrossFireX™ system, a second ATI Radeon™ HD 5870 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
I recommend a nice PSU like the Corsair 750W, but you only really need a 600W minimum. Just make sure you have 4 each 6-pin power connectors.
A good 750W unit will be totally adequate, yes.
Personally I'd prefer an 850W (as you can see) because it provides more overhead, but ... a good 750W unit is fine. By good, I mean like Corsair, Silverstone, Enermax, Seasonic, Antec True-series, Coolermaster Real Power Pro or Silent Power-series ... that sort of good. Not HEC, Rocketfish, Xion, Coolmax, Raidmax, Ultra (although the X3 series is fine), or Thermaltake TR2-series. OCZ would be borderline, probably fine.
Two 5870's and an i7, all overclocked, you're looking at using *maybe* 600W if you ran like Super PI and Furmark at the same time. Realistically, you'd probably almost never actually use > about 525W.
Im running a pair of 280's in sli, with a 750 watt psu. But if you want wriggle room, id say between 850 to around 950 for long term investment.
1 - 13 of 13 Posts
