what would be a good step up?
1009 Views 39 Replies 5 Participants Last post by  mac overclocker
what would be a good step up from my current processor? only 95W cpus that are supported by my mobo here is the list http://www.ecs.com.tw/ECSWebSite/Sup...uID=69&LanID=0
thanks
1 - 20 of 40 Posts
Originally Posted by mac overclocker View Post
how much do you have to spend
well if i sell my current CPU plus my dual core I'm gonna say about 150 maybe
o go top of thee line AMD Phenom II X4 965 Black Edition but get aftermarket cooling
my mobo only supports 95W cpus and no phenom II's
ok then get the 925
not supported its only supports Phenom II's that have E after them see this is the supported list http://www.ecs.com.tw/ECSWebSite/Sup...uID=69&LanID=0
it may be worth it to upgrade your mother board and proses
yeah but with 150 is it even worth it?
i though you sed 250
even with 150 id buy a mother baord and save up for a new peosesor
yeah it was a typo unless i sell my mobo too i wont even get 150 ill bet
If it doesn't support Phenom II's, I would suggest you sell your mobo, and get a cheap 780G / 785G board, and get a Phenom II dual or tri core.
Or you could go with like a Phenom 9850 / 9950...but its not going to be much better than your current CPU at all.
Sell the board and CPU(s), and replace both so you can use a Phenom II or Athlon II.
hers a deal this cpu is a duel car but it will own you cpu in a speed test and the motherbord alows for new cpus
http://www.newegg.com/Product/ComboD...t=Combo.297148
o and its 149
o and its 149
i play grand theft auto 4 so a dual core is a no go
maybe one of the cheaper quads? It sounds like overclocking will be a necessity then.
why not
that game runs like crap on anything less than a quad-core
that's what i was thinking
are you rinig it on your cpu
i hope you mean running if so then yes i can get about 30-40 fps depending on what happening
1 - 20 of 40 Posts
